TwinTurbo.NET: Nissan 300ZX forum - Re: The N/A ecu doesn't have the "output" to control boost
Cjw3
on November 03, 2012 at 11:40 PM
The N/A ecu doesn't have the "output" to control boost (n/m)
posted by Zvil (FL)
on November 03, 2012 at 09:42 PM
Thanks..
Cj
Can I use upgraded 16 bit ecu in 92 N/A to TT w/ 95 motor?
Zvil (FL)
10:49:19 11/03/12
This question should still be answered but I magically
Zvil (FL)
13:04:45 11/03/12
Re: Can I use upgraded 16 bit ecu in 92 N/A to TT w/ 95 motor?
Cjw3
16:14:35 11/03/12
Zvil (FL)
21:42:34 11/03/12
Re: The N/A ecu doesn't have the "output" to control boost -
Cjw3
23:40:23 11/03/12
you should install an 8 bit ecu instead
aliaZ
16:36:21 11/03/12
Use a TT ecu, TT EFI @ TT fuel pump & controller (n/m)
02:01:38 11/05/12
wouldn't I have to run an extra control wire to the fuel
Zvil (FL)
07:15:46 11/05/12
Depends on the production year of the car. But even if you
07:56:33 11/05/12
I think I want to use my current setup unless it's bad >
Zvil (FL)
08:40:25 11/05/12
